Добрый день!
Ответьте, пожалуйта, сколько будет стоить лечение ошибки CC
после того, как PC-3000 стал поддерживать решение этой проблемы?
[url=http://www.acelaboratory.com/pc3000.udma.ver4.13.php]http://www.acelaboratory.com/pc3000.udma.ver4.13.php[/url]
The new version 4.13 PC-3000 for Windows (UDMA)New!
Seagate
We appended the new utility for all HDDs of Seagate 7200.11 family, which has the following possibilities:
translator regeneration (restoration)
SMART settings recovery, SMART log cleaning
G-list clearance
MR heads test
All utility functions do not damage user data!
The utility allows to solve the following problems:
HDD is detected in OS, but has 0Gb capacity
HDD does not run the readiness, is not detected in OS, the following messages are ejected to the terminal:
FlashLED - Failure code:000000CC Failure Address:xxxxxxxx
The expert system which allows to detect HDD failure and remove it in the automatic mode without loss of the user data is appended to the utility. This mode will be very useful for beginners.
