Умирает или нет? (помогите разобраться) ¶
От: sag 13 ноября 2016 г. 11:27
Привет!
Ничего не понимаю в этом, не могли бы дать совет, разъяснить, в каком состоянии диск, а то сдается мне, что умирает диск (
Model: ST500LM012 HN-M500MBB
Firmware: 2AR10002
Serial: S2RSJ9DCA64136
LBA: 976773168
Report By: HDDScan for Windows version 3.3
Report Date: 11/13/2016 12:08:26 AM
Open Disk
Test : VR-Verify
Executing
Block start at 4029440 time 59ms
Block start at 4063744 time 54ms
Block start at 4141056 time 76ms
Block start at 4618240 time 410ms
Block start at 5999360 time 399ms
Block start at 41428480 time 647ms
Block start at 63583488 time 281ms
Block start at 84207872 time 65ms
Block start at 204033536 time 55ms
Block start at 216817920 time 55ms
Block start at 217947136 time 56ms
Block start at 219589120 time 98ms
Block start at 220667904 time 56ms
Block start at 221517312 time 55ms
Block start at 222469376 time 55ms
Block start at 223532800 time 56ms
Block start at 223911424 time 54ms
Block start at 225661952 time 55ms
Block start at 226153984 time 120ms
Block start at 226256384 time 55ms
Block start at 226878464 time 56ms
Block start at 227136256 time 54ms
Block start at 227213056 time 54ms
Block start at 255764736 time 54ms
Block start at 255969536 time 65ms
Block start at 258900224 time 55ms
Block start at 261451008 time 56ms
Block start at 269047296 time 55ms
Block start at 270341376 time 56ms
Block start at 310109184 time 121ms
Block start at 314238976 time 63ms
Block start at 335695616 time 1145ms
Block start at 335695872 time 124ms
Block start at 342251520 time 54ms
Block start at 342356224 time 55ms
Block start at 344092160 time 51ms
Block start at 344092416 time 129ms
Block start at 350749440 time 75ms
Block start at 350752256 time 76ms
Block start at 350752512 time 54ms
Block start at 351273216 time 55ms
Block start at 351273472 time 53ms
Block start at 351273728 time 56ms
Block start at 351603456 time 55ms
Block start at 351603712 time 54ms
Block start at 351604736 time 55ms
Block start at 351604992 time 56ms
Block start at 351605504 time 53ms
Block start at 351605760 time 54ms
Block start at 351606272 time 55ms
Block start at 351607808 time 55ms
Block start at 351608064 time 54ms
Block start at 351608320 time 53ms
Block start at 351609088 time 55ms
Block start at 351610112 time 55ms
Block start at 351610368 time 54ms
Block start at 351612928 time 55ms
Block start at 351615744 time 64ms
Block start at 351616000 time 56ms
Block start at 351616256 time 54ms
Block start at 351616512 time 54ms
Block start at 351616768 time 54ms
Block start at 351617536 time 55ms
Block start at 351617792 time 54ms
Block start at 351618560 time 55ms
Block start at 351903488 time 65ms
Block start at 364104192 time 56ms
Bad block found, start LBA : 365705728
Block start at 365705984 time 119ms
Block start at 365722624 time 55ms
Block start at 371467264 time 55ms
Block start at 371546624 time 55ms
Block start at 371546880 time 259ms
Bad block found, start LBA : 371547136
Bad block found, start LBA : 371547392
Bad block found, start LBA : 371547648
Block start at 371547904 time 122ms
Block start at 371548672 time 118ms
Bad block found, start LBA : 371560448
Bad block found, start LBA : 371560704
Bad block found, start LBA : 371560960
Block start at 371561216 time 1297ms
Block start at 371561728 time 237ms
Bad block found, start LBA : 371561984
Bad block found, start LBA : 371562240
Bad block found, start LBA : 371562496
Block start at 371562752 time 110ms
Bad block found, start LBA : 371564032
Bad block found, start LBA : 371564288
Bad block found, start LBA : 371564544
Block start at 371564800 time 99ms
Bad block found, start LBA : 371589632
Bad block found, start LBA : 371589888
Block start at 372013056 time 98ms
Block start at 372013824 time 76ms
Block start at 372014080 time 172ms
Block start at 372015104 time 228ms
Block start at 372015616 time 119ms
Block start at 372015872 time 54ms
Block start at 372016896 time 186ms
Block start at 372060672 time 56ms
Bad block found, start LBA : 390055936
Bad block found, start LBA : 390056192
Block start at 390056448 time 434ms
Bad block found, start LBA : 390057216
Bad block found, start LBA : 390057472
Bad block found, start LBA : 390057728
Block start at 390057984 time 348ms
Block start at 390058240 time 128ms
Bad block found, start LBA : 390059008
Bad block found, start LBA : 390059264
Bad block found, start LBA : 390059520
Block start at 390059776 time 219ms
Block start at 390060032 time 139ms
Block start at 390128896 time 282ms
Bad block found, start LBA : 390129408
Bad block found, start LBA : 390129664
Bad block found, start LBA : 390129920
Bad block found, start LBA : 390130176
Block start at 390130432 time 7827ms
Bad block found, start LBA : 390130944
Block start at 390131200 time 129ms
Block start at 390158592 time 57ms
Block start at 390158848 time 53ms
Block start at 390163200 time 55ms
Block start at 390214144 time 55ms
Block start at 390218752 time 55ms
Block start at 390232064 time 55ms
Block start at 425107712 time 53ms
Block start at 425109248 time 367ms
Block start at 425109504 time 127ms
Block start at 425111040 time 376ms
Block start at 425111296 time 137ms
Block start at 425112576 time 101ms
Block start at 425112832 time 227ms
Block start at 425113088 time 128ms
Block start at 425114880 time 55ms
Block start at 425208064 time 65ms
Block start at 425208320 time 163ms
Block start at 493846528 time 410ms
Block start at 496519680 time 61ms
Block start at 497399296 time 74ms
Block start at 507746304 time 195ms
Block start at 519724544 time 57ms
Block start at 538183680 time 119ms
Block start at 556573440 time 150ms
Block start at 558724608 time 76ms
Block start at 571233536 time 89ms
Block start at 572481280 time 281ms
Block start at 572729344 time 65ms
Block start at 576427264 time 119ms
Block start at 581035264 time 249ms
Block start at 581786624 time 67ms
Block start at 596088576 time 106ms
Block start at 600252928 time 90ms
Block start at 600253184 time 73ms
Block start at 636705536 time 52ms
Block start at 675918848 time 111ms
Block start at 678393856 time 55ms
Block start at 679737344 time 91ms
Block start at 680229632 time 77ms
Block start at 705617152 time 91ms
Block start at 750404352 time 55ms
Block start at 753874432 time 69ms
Block start at 754635520 time 85ms
Block start at 754637056 time 91ms
Block start at 763919616 time 139ms
Block start at 809818368 time 76ms
Block start at 809818624 time 89ms
Block start at 809818880 time 54ms
Block start at 811427584 time 55ms
Block start at 819004672 time 88ms
Block start at 821710080 time 1371ms
Block start at 821710336 time 126ms
Block start at 837495040 time 696ms
Block start at 837495296 time 133ms
Block start at 845769728 time 79ms
Block start at 898037760 time 56ms
Block start at 925556992 time 63ms
Block start at 932000256 time 55ms
Block start at 934953216 time 231ms
Block start at 937753088 time 69ms
Block start at 938565632 time 55ms
Block start at 938671616 time 54ms
Block start at 944728576 time 121ms
Block start at 956445184 time 57ms
Block start at 956636416 time 61ms
Block start at 956638720 time 186ms
Block start at 956638976 time 77ms
Block start at 957279488 time 56ms
Block start at 964600832 time 134ms
Block start at 964894720 time 177ms
Block start at 966365440 time 54ms
Block start at 966366464 time 62ms
Block start at 967526656 time 65ms
Block start at 969103104 time 56ms
Block start at 969105152 time 56ms
Block start at 970411008 time 66ms
Block start at 970411264 time 66ms
Block start at 970411520 time 56ms
Block start at 970411776 time 68ms
Block start at 970412032 time 56ms
Block start at 970426624 time 79ms
Block start at 970426880 time 56ms
Block start at 970863872 time 203ms
Block start at 971617024 time 126ms
Block start at 972020224 time 151ms
Block start at 972291840 time 56ms
Block start at 972292864 time 77ms
Block start at 974215168 time 62ms
Block start at 974808064 time 56ms
