Спасибо. Скачал R.tester пока разбираюсь.
С продавцом всё понятно. что маловероятно, просто хочется ещё и самому разобраться, раз уж взялся
Я правльно понимаю, что отсутствие в G list циферок - это хорошо?
Вот что вижу по WD:
; Model: WD WD6001BKHG-50D22
; Serial: WXU1E83NFCK9
; Firmware: SFX9
0 G-LIST Number of reallocated sectors (pCHS) ** GROWN **
1930 P-LIST Number of Primary defects (pCHS) ** FACTORY **
00-00 PFA Status: ** GOOD **
35'C T Current Temperature
69'C T Reference Temperature
213 CSS Accumulated Start/Stop Cycles
453127 WRITE Error Corrected Without Substantial Delay
842 WRITE Error Corrected With Possible Delays
844 WRITE Total Error Corrected With Retries
453969 WRITE Total Error Corrected
842 WRITE Total Times Correction Algorithm Processed
24373917970432 WRITE Total Bytes Processed ( 22.17 Tb )
0 WRITE Total Uncorrected Errors
14695 READ Error Corrected Without Substantial Delay
26 READ Error Corrected With Possible Delays
57 READ Total Error Corrected With Retries
14721 READ Total Error Corrected
26 READ Total Times Correction Algorithm Processed
7845358983168 READ Total Bytes Processed ( 7.14 Tb )
0 READ Total Uncorrected Errors
0 VERIFY Error Corrected Without Substantial Delay
0 VERIFY Error Corrected With Possible Delays
0 VERIFY Total Error Corrected With Retries
0 VERIFY Total Times Correction Algorithm Processed
0 VERIFY Total Bytes Processed
0 VERIFY Total Uncorrected Errors
287616 - Recoverable Non-Medium Error Events
по seagate:
; Model: SEAGATE ST600MM0006
; Serial: S0M1C2LJ
; Firmware: 6102
1408 P-LIST Number of Primary defects (pCHS) ** FACTORY **
68'C T Reference Temperature
225d 17h POH Power-On Time (325042 minutes)
702 CSS Accumulated Start/Stop Cycles
0 WRITE Error Corrected With Possible Delays
0 WRITE Total Error Corrected With Retries
0 WRITE Total Times Correction Algorithm Processed
3308097849856 WRITE Total Bytes Processed ( 3.01 Tb )
2079063422 READ Error Corrected Without Substantial Delay
0 READ Error Corrected With Possible Delays
0 READ Total Error Corrected With Retries
2079063422 READ Total Error Corrected
0 READ Total Times Correction Algorithm Processed
2018569198080 READ Total Bytes Processed ( 1.84 Tb )
2228 - Recoverable Non-Medium Error Events
Можно создать топик в профильной теме... Сделать?
