3 декабря 2019 г.
Ionov_Andrey
Volodymyr Gintov
Сегодняшний апдейт :
What's new in version 7.14.1: * Added double-degraded RAID6 recovery with DELL Equallogic diagonal XOR; * Search for APFS encryption keys: - added displaying of both KEK and VEK records; - added search for older keyring blocks for known APFS containers. * Fixed bug building degraded RAID4/RAID5 VX; * Fixed issue with RAID6 adaptive reconstruction when one disk is missing; * Pattern-storage/defects mask: extended length of pattern field to 1536 symbols; * Fixed bug with parsing Novell NSS 'big' partition; * Optimization of HFS+ scan result set; * Fixed issue with focus location in hex 'go to' dialog (fixed base position); * In partition manager: fixed bug removing partitions.
pc3000velkoo
круто
ufsexplorerbot
7.14.1 http://www.sysdevlabs.com/download/ufsxpci.exe http://www.ufsexplorer.com/download_pro.php * Added double-degraded RAID6 recovery with DELL Equallogic diagonal XOR; * Search for APFS encryption keys: - added displaying of both KEK and VEK records; - added search for older keyring blocks for known APFS containers. * Fixed bug building degraded RAID4/RAID5 VX; * Fixed issue with RAID6 adaptive reconstruction when one disk is missing; * Pattern-storage/defects mask: extended length of pattern field to 1536 symbols; * Fixed bug with parsing Novell NSS 'big' partition; * Optimization of HFS+ scan result set; * Fixed issue with focus location in hex 'go to' dialog (fixed base position); * In partition manager: fixed bug removing partitions. ---------------------- Release summary: Version: 7.14.1 Last update: 03.12.2019 Type of update: major ---------------------- Find more information about this software on the program web site.
Volodymyr Gintov
Bot с тормозами )
22 декабря 2019 г.
❯ Bot с тормозами )
С хостингом проблема. Связь пропадает, а может вообще там всё целиком падает, не вдавался.
27 декабря 2019 г.
ufsexplorerbot
7.15 http://www.sysdevlabs.com/download/ufsxpci.exe http://www.ufsexplorer.com/download_pro.php * Added Adaptec RAID6 (dedicated XOR) with degraded mode; * Added degraded/double-degraded recovery for HP MSA RAID6 with diagonal XOR; * Added support of HP ADG RAID6 coefficients (up to 48 drives); * Added support of custom coefficients for RAID6 Reed-Solomon code; * Added Compact Left Symmetric rotation for RAID5 (for LSI RAID50 etc.); * Hexadecimal search with any block size (big blocks scanned with jumps); * Fixed bug with FAT/FAT32 file system indexing. ---------------------- Release summary: Version: 7.15 Last update: 27.12.2019 Type of update: major ---------------------- Find more information about this software on the program web site.
6 февраля 2020 г.
7.16 http://www.sysdevlabs.com/download/ufsxpci.exe http://www.ufsexplorer.com/download_pro.php * Fixed bug reading legacy ReFS volumes; * Fixed issue with no error reporting when disk is imaged to write-protected disk; * Saving of processed data can be continued on existing file; * Enabled manual editing of Read-once storage; * Fixed bugs in FAT recovery recovery module: - Removed record attributes verification for Volume Name entry; - Fixed bug with reconstruction of fragmented files when second FAT table is damaged. * Modified procedure of classification of found MFT entries from unlinked MFT chunks. ---------------------- Release summary: Version: 7.16 Last update: 06.02.2020 Type of update: major ---------------------- Find more information about this software on the program web site.
14 февраля 2020 г.
pc3000velkoo
Парни , когда задали патерн для бед блоки - при копирование файлов , будут попадать в списке ВСЕ которие содержать его ?
Volodymyr Gintov
там есть опция , сохранение с фильтром ,в ней внизу галка "удалять файлы с бэдами". Если на файл пришелся бэд он будет удален при сохранении
pc3000velkoo
Спасибо Вова , но если не задал - в логе будут они ?
Первий раз пользуюсь данной опции
Volodymyr Gintov
если фильтр не задал, сохранено будет все что видит и в лог не попадет
pc3000velkoo
Запустил с филтром , но наверно не плохо иметь и опция только логировать . Ето как пожелание к разработчика :) мувики например и с беди играются
Volodymyr Gintov
в след апдейте будт опция сохранять файлы с бэдами в отдельную папку
pc3000velkoo
Супер !
последний вопрос - лог пропущених будет ?
3 марта 2020 г.
Volodymyr Gintov
Скоро будет
Pigeon_hd
вот и новый де растет
Это признание ACELab 👍🏻 MRT их в большей степени копировали, другие компании тоже, но вот вопрос – зачем? Надеюсь, что это простой вопрос 💁🏻‍♀️
Volodymyr Gintov
В какой части вы увидели копирование Acelab?
master_dudnikov
❯ В какой части вы увидели копирование Acelab?
Зеленые кубики видишь? 😉
Pigeon_hd
и снизу лампочки
Volodymyr Gintov
Есть патент на зелёный цвет и на кубики? У предшественников пс3000 ,mhdd , гипотенуза прямоугольничков другой длинны ? ))) Не нравится цвет , сделают желтенький если нннадо ))
А красенькое это что ?
Pigeon_hd
предлагаю, чтобы быть непохожими на аселаб - сделать прочитанные кубики черными, бэдблоки зелеными. А, и сделать кружочками
Треугольниками или кристаликами.
Volodymyr Gintov
Поддерживаю ))
У Вас проблемы с ЧСВ или это возрастное и необратимое? Что за дух непрофессионализма и бестактность в ответе на вполне чётко сформулированный вопрос 🤦🏻‍♀️Shame on you 👎🏻 MRT не копирует? Копирует! Это неоспоримый факт. А вот на счёт UFS, с моей стороны, не было утверждения, но был вопрос в контексте визуализации. Возможно в Вашей системе координат оскорбительный, но я не проследовала и не преследую цели кого-либо оскорбить💁🏻‍♀️
Volodymyr Gintov
Контекст визуализации в вашем вопросе не идентифицируется )
Хорошо. С контекстом разобрались. Каков ответ? Интереса ради на других ПАК проверю, но уже точно могу сказать, что система визуализации этой части не похожа ни в Atola, ни в Salvation, ни в DeepSpar (ещё не успела гарантированно проверить)... список можно продолжать, хотя у всех очень схожая и по понятным причинам единая концепция 💁🏻‍♀️ Но очень похожа именно на трактор. Странное совпадение.
Volodymyr только в PC-3000 Portable III панель регистров совсем немного отличается 💁🏻‍♀️ А в PC-3000 SAS, PC-3000 Express, PC-3000 UDMA-E фактические схожие с тем скрином, который ранее представлен. @master_dudnikov @Graf_datex @mikhail_olin – guys, речь НЕ шла о битовой карте 🤷🏻‍♀️
MaxHDD
Предложите свое... Всего-то делов. Ругать каждый умеет. Для разминки попробуйте дышать нестандартным образом. Не как другие... ну, люди, хотя бы...
Pigeon_hd
я все равно не понял, о чем говорит Виктория. Если не о карте - значит о регистрах. В моем софте они тоже так представлены. Как их еще можно представить? ну, можно выпендриться, и, к примеру, вертикально их расположить. Удобство под вопросом, но как оригинально будет!
MaxHDD
Серж, главное не что. Главное говорить. Побольше. И с эмоджи в каждой строке
И да, те квадратики ни разу не из DE пошли
Внезапно... MS Scandisk for DOS
Внезапно Norton...
