10.11 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery/ * Apple Core Storage (HFS+) volumes: added support of type 24 data allocation; * Fixed issue with using of LUKS2 passwords with null-symbols; * When saving RAID configuration built on 'flat' disk images with sector size trasformation, this transformation is now preserved; * Fixed issue with support of newer EnCase Ex01 forensic image format (tests performed with FALCON-NEO imager); * Added support of DFL-DE sector maps (both plain and compact) plus log file of other software with disk imaging capabilities; * Fixed issue with using of wrong disk if source disk is disconnected and replaced with a different one; * When source disk is reconnected to a different device path, the software attempts to restore connection by finding the disk by its serial (when possible); * Reworked scan abortion procedure to allow much faster scan abortion on an area of defect blocks; * NTFS scan procedure: - More detailed parsing of directory indexes for better recovery of file names; - Optimization for better support of file 'undelete' after deletion by the Linux NTFS driver. ---------------------- Release summary: Version: 10.11 Last update: 06.11.2024 Type of update: major ---------------------- Find more information about this software on the program web site.
10.11.1 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery/ * Fixed critical issue with parallel access to disks (caused by an unexpected behaviour of device handle duplication API); * Fixed crash bug issue caused by decoding of some malformed MPEG4 video frames (for purposes of 'preview'); * Added support of 'still frame preview' for more video formats. ---------------------- Release summary: Version: 10.11.1 Last update: 11.11.2024 Type of update: critical ---------------------- Find more information about this software on the program web site.
Hello, I am interested in testing ufs explorer technician software and hp msa plug in. Please give me the trial code of these two software my system id :WR070106-A16154B75DDFA430ECAAEF2B ++++ Здравствуйте, меня интересует тестирование технического программного обеспечения ufs explorer и плагина hp msa. Пожалуйста, дайте мне пробный код этих двух программ. мой системный идентификатор: WR070106-A16154B75DDFA430ECAAEF2B
hi The proffesianal version does not support msa 2040 POOL recovery like the Technician version. Is there a way that I can recover from the entire POOL with this Proffesional version? +++++ Профессиональная версия не поддерживает восстановление пула msa 2040, в отличие от версии Technician. Есть ли способ восстановить данные из всего ПУЛА с помощью этой профессиональной версии?
Сейчас работаю с профессиональной версией. Но у меня возникла проблема с восстановлением ваших данных из хранилища MSA 2040. Потому что у Сторича есть пул и внутри него 7-5 рейдов. Только один из RAID5 исправен и показывает правильную емкость. Остальные рейды5 показывают емкость 0. Судя по всему, проблема в структуре хранения POOL. С другой стороны емкость томов правильная, но их надо восстанавливать. Я делаю образы всех рейдов примерно с 65 жестких дисков, чтобы можно было с ними правильно сделать рейд5. Но профессиональная версия не поддерживает восстановление хранилища POOL. ++++ I am currently working with the professional version. But I have a problem to recover your data from MSA 2040 storage. Because Storich has a pool and there are 7 to 5 raids inside it. Only one of the raid5s is healthy and shows the correct capacity. The remaining raid5s show the capacity of 0. Apparently, the POOL storage structure has a problem. On the other hand, the capacity of the volumes is correct, but they must be recovered. I am taking images of all raids from about 65 hard drives, so that I can make raid5 properly with them. But the professional version does not support POOL storage recovery.
❯ Сейчас работаю с профессиональной версией. Но у меня возникла проблема с восстановлением ваших данных из хранилища MSA 2040. Потому что у Сторича есть пул и внутри него 7-5 рейдов. Только один из RAID5 исправен и показывает правильную емкость. Остальные рейды5 показывают емкость 0. Судя по всему, проблема в структуре хранения POOL. С другой стороны емкость томов правильная, но их надо восстанавливать. Я делаю образы всех рейдов примерно с 65 жестких дисков, чтобы можно было с ними правильно сделать рейд5. Но профессиональная версия не поддерживает восстановление хранилища POOL. ++++ I am currently working with the professional version. But I have a problem to recover your data from MSA 2040 storage. Because Storich has a pool and there are 7 to 5 raids inside it. Only one of the raid5s is healthy and shows the correct capacity. The remaining raid5s show the capacity of 0. Apparently, the POOL storage structure has a problem. On the other hand, the capacity of the volumes is correct, but they must be recovered. I am taking images of all raids from about 65 hard drives, so that I can make raid5 properly with them. But the professional version does not support POOL storage recovery.
Hi! Give us your contacts
❯ Hi! Give us your contacts
hi Sebastian Pereiro i send you my email address in your pv
From which country you are? Thera no trial version for msa plugin, only for ufs Technician . But msa2040 can be done even without, based on metadata , manually creating translator file loading it into ufs pro normal version
10.12 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery/ * Introduced licensing with Thales Sentinel LDK: Registration codes must be replaced with Sentinel digital licenses; * Introduced cross-platform (OS-independent) licensing; * Rework of 'transform file system files' function to support NAS-specific transformations even if metadata is not detected automatically: - Added possibility to specify explicitly file repository folder path; - It is also possible to specify a custom (format-specific, pre-saved) 'cloud database'; * Added support of Synology Drive 'cloud' repository to 'transform file system files' function; * Direct decryption of Synology LUKS volumes: fixed bug with decoding of base64-encoded rkey-file content by the 'password' dialogue; * Fixed issue with BitLocker search when partition is available, but superblock is lost; * Automatic RAID reconstruction: fixed a bug that prevented automatic assembly of 'stripe over mirrors' in some scenarios; * Fixed issue with support of MS Storage Spaces with reported 'mirror/single component/2 copies' configuration; * Fixed issue with decryption of BitLocker on storages with 4K sectors (affected BitLocker on Storage Spaces); * Found and fixed a crash bug with direct reading of ReFS file system in some rare scenarios; * Fixed a bug with reading sparse files on ZFS file system; * File search tool is extended with 'search by content' option: - Possibility to search for a specific pattern: at a fixed position or anywhere in a file; - An option to specify 'content type' to search for (including custom, user-defined types) - independently or in conjunction with the search by pattern; * Restoration of symbolic links: - Now, by default, the software will attempt to restore symbolic links on the target; - Added possibility to configure and save linked files instead of links (useful for Promise Apollo and similar scenarios); - In the 'Copy selection (advanced)' tool, the above setting can also be enabled for once; * Ext4 file system scan: removed duplicate files found in folder to make it more useful for data recovery; * In raw recovery: added built-in support for some less common audio formats (FLAC, AMR). ---------------------- Release summary: Version: 10.12 Last update: 03.02.2025 Type of update: major ---------------------- Find more information about this software on the program web site.
10.12.1 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery/ * Relaxed license checks to prevent cloud license deactivation in case of temporary internet connection loss. * Added possibility to hide physical and logical drives in the UI (such as a 'system' drive or a 'target' drive(s)). - Added special UI to unhide or open a hidden storage. * In the disk imager: the software now automatically creates a '.props' file containing the properties of the imaged device (for a target format other then .sdlsp). * When opening image files, the software now checks for the presence of a '.props' file and restores the name, serial number and WWN (if available). - Added the ability to force the serial number and/or WWN for an image file created by third party software by using of '.props' files. * Fixed a software crash bug on some older x86-based CPUs. ---------------------- Release summary: Version: 10.12.1 Last update: 10.04.2025 Type of update: major ---------------------- Find more information about this software on the program web site.
Здравствуйте, друзья У меня компания по восстановлению данных, и мы еще не сталкивались с подобными системами У меня хранилище IBM FlashSystem 5030. 24 диска. Диски цельные, PC-3000 не поддерживает, UFS тоже. В результате моего исследования оказалось, что данные можно восстановить с помощью UFS Explorer Technicain и плагина восстановления данных для IBM Storwize. Кто-нибудь имел опыт работы с подобным?
Добрый день. Попробуйте связаться напрямую с производителем софта. Сторвайзы ЮФС восстанавливает хорошо.
❯ Здравствуйте, друзья У меня компания по восстановлению данных, и мы еще не сталкивались с подобными системами У меня хранилище IBM FlashSystem 5030. 24 диска. Диски цельные, PC-3000 не поддерживает, UFS тоже. В результате моего исследования оказалось, что данные можно восстановить с помощью UFS Explorer Technicain и плагина восстановления данных для IBM Storwize. Кто-нибудь имел опыт работы с подобным?
Ну купите технишн и плагин , сделаете заказ. Проблема будет с лицензией для РФ
Человек не из РФ.
10.13 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery/ * Asustor NAS support in 'media manager': - Fixed issue with recognition of some encrypted shared folders; - Added possibility to decrypt shared folders using 'backup keys' instead of passwords; * Fixed bug with SQLite metadata parser that prevented loading of some databases for virtual file system transformations; * In password unwrapping tool: added support of password extraction from Asustor 'key backup' files; * 'Read' support of newer ESX OSDATA partition with VMFS6 format; * Added an experimental support of NTFS Restore Points (to virtually roll back the volume to the checkpoint); * Fixed support of Apple Core Storage volumes that was 'broken' in recent software versions; * Btrfs file system: fixed issue reading RAID10 metadata format with missing disks; * Fixed bug in adaptive reconstruction algorithm for RAID1E; * FAT32 scan: better recognition of start position of file allocation table with severe damage to both copies; * Updated procedure of file restoration from 'Recycle.Bin': now also restoring some previously skipped files. ---------------------- Release summary: Version: 10.13 Last update: 19.05.2025 Type of update: major ---------------------- Find more information about this software on the program web site.
10.14 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery/ * Microsoft data deduplication support was deeply reworked for both NTFS and ReFS: - Fixed an issue with incorrect data on ReFS (and on NTFS in some scenarios); - Fixed an issue with consistency of large deduplicated files; * Fixed issue with LUKS2 decryption with sector size over 512 bytes; * Asustor MyArchive: added support of LUKS decryption (requires 'Ausustor MyArchive' password transformation OR use of the backup key); * Intel ISM configurations: fixed issue with detection on image files in some scenarios; * Microsoft Storage Spaces: - Added support of SPCACHE storage caching mechanism (used in recent Windows Server versions to speed up 'Parity' volumes); - Automatic Storage Space assembly procedure is modified to support Transaction log or Cache (if available); - Automatic procedure now can be configured to not assemble spaces, assemble just a plain volume or assemble with log/cache enabled (default); - Fixed issue updating configurations with missing drives; * ReFS file system: - Fixed issue that caused duplication of files produced by the file system scan in some scenarios; - Fixed issue with support of reparse points with a shorter metadata chain (ReFS version 3.14); * Fixed issue displaying of some detected complex volumes (required additional 'refresh' operation); * Added detection of deleted partitions when disk is initialised with an empty GPT (only 'Reserved' partition is defined); * ExFAT scan: a couple of fixes for better recovery quality of folder structure. ---------------------- Release summary: Version: 10.14 Last update: 01.07.2025 Type of update: major ---------------------- Find more information about this software on the program web site.
10.15 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery/ * Added a dedicated 'Detect and open a contained file system' tool (file context menu and toolbar) to quickly check content of image files on a new tab; - Added support of archives (by means of virtual ArchFS) to be processed in this way; - Fixed bug with recognition of DMG files for quick view (including current viewer); * Added support of FreeBSD GEOM::ELI (GELI) full-disk encryption (including AES CBC/XTS and Camellia CBC); - Support of pool GELI-based encryption of FreeNAS version 11 and below (decryption requires the exported 'key file'); * Update to Drobo BeyondRAID Assistant tool: - Added automatic detection of 'block metadata size' before scan; - Added adjustment of block metadata size for cases with different meta block size on disks; - Also added verification and of validity and compatibility of 'block metadata size' before starting the scan; * Asustor NAS in Media Manager: - Fixed issue with not displaying content for single-disk NAS; - Added search for RAID components even if NAS-specific metadata is not present on them; * ZFS scan: fixed a crash bug in LZ4 decompression algorithm; * ExFAT scan: reworked 'completion' stage to work significantly faster, as well as fixed an issue with an 'infinite completion' is some scenarios; * NTFS file system scan: fixed bug with invalid reconstruction of bigger files from the Journal (log) file; * Fixed bug with restoration of connection to a source disk image (or a virtual disk) after a storage with such an image is reconnected; * Linux version: fixed problem running the software with 15/16bit desktop colour depths. ---------------------- Release summary: Version: 10.15 Last update: 01.09.2025 Type of update: major ---------------------- Find more information about this software on the program web site.
10.16 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery/ * File system transformation: added support of 'MongaStorage' container type on Promise Apollo NAS; * For ZFS file system: - Added special tool to open the file system at a specific recent transaction to potentially access recently deleted data without a scan; - Option to search (scan) for file system transactions that are not available through 'uberblock' references; - Quick scan of individual transactions to perform a 'virtual repair' of minor consistency issues caused by overwrite; * Microsoft Storage Spaces: Fixed issue with data mapping calculation on multi-tier spaces; * Fixed bug with adaptive reconstruction of RAID10/1E; * Added basic support of RAID metadata created by ASMedia ASM1xxxR chips; * HFS+ scan: fixed issue in Journal analysis procedure that can cause excessive memory use and even crash in some scenarios; * Refactored code of ZFS access module to fix a 'ZFS access' bug in Linux software version caused by incorrect code optimisation by gcc compiler. ---------------------- Release summary: Version: 10.16 Last update: 11.10.2025 Type of update: major ---------------------- Find more information about this software on the program web site.
deepspar disk image Selling tools
2062
I want to sell tools
10.17 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery/ * Added experimental 'read' support of EnCase 'Logical Evidence' files (L01/Lx01); * Added basic/experimental support of VBK backups; - Also added support of VIB (delta) files and applying these deltas to the base backup; * EnCase E01 format: - Added extraction of the source device name and serial number; - Support of 'virtually unlimited' number of image file segments (support for extensions sequence according to both EnCase and FTK Imager formats); * EnCase Ex01: format: - Fixed issue with invalid size and added extractraction of the source device name and serial number; - Added support of extraction and verification of SHA256 and SHA512 hashes; - Support of 'virtually unlimited' number of image file segments (support for extensions sequence according to the EnCase format); * AFF4 support: fixed some ZIP64 compatibility issues and also added implementation of LZ4 compression; * Applying delta files to base (snapshot) virtual disks: added an option to select a base storage (snapshot) of a different size to support resize scenario; * Refactored code of 'blake2b' implementation that caused incorrect code optimisation by compiler under macOS (affected functionality of LUKS2 decryption); * In file system transformation tool: added 'Convert to a photo library' tool to convert any source folder with photos to a 'Photo library' of a fixed structure by using the file metadata; * Added support of a couple of variations of HighPoint RocketRAID metadata; * Making disk image in EnCase format: - Image File segment extension sequence is extended according to the EnCase format; - Added 'header2' section to preserve the source storage name and serial number; * Fixed issue with proper ATA disk addressable capacity detection when disks with size over 2TB are reduced to below 2TB with HPA/DCO; * Fixed issues reading WOF-compressed files on NTFS file system when default DATA attribute not present. ---------------------- Release summary: Version: 10.17 Last update: 17.11.2025 Type of update: major ---------------------- Find more information about this software on the program web site.
10.18 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery/ * Added the possibility to decrypt a specific APFS volume to the Explorer context menu; * APFS file system: added a tool for direct quick access to APFS transactions (generations) to potentially access recently deleted files or volumes without a scan; - Also added support of search for older ('lost') transaction; * Added a function to save/restore the list of found transactions for both ZFS and APFS; * Fixed issue with support of larger VBK files; * When scan is resumed from SSDB file, added possibility to save automatically another SSDB from the continued scan, including periodic SSDB backups; * RAID metadata support: added one more variation of SilImage RAID metadata; * Microsoft Storage Spaces: - Fixed issue with support of cache volumes with sector size 4KB; - Added support of volume metadata version 17 (Win11 25H2); * Support of archives: - Added support of LZMA2 decompression; - Added read support of .xz archives; - Added read support of .xar archives; * In the embedded file viewer: - Added preview of newly supported types of archives; - Added extraction of preview picture for 3MF and F3D model formats; - Also fixed a couple of issues with proper displaying of texts (such as 'Error', 'Loading...' etc.); * NTFS file system scan: - Fixed issue that prevented running a full 'quick' scan in some scenarios; - Updated transaction log (journal) analysis procedure for better recovery of deleted files in some scenarios; * FAT/FAT32 scan: updated for better file system structure recovery in some scenarios. ---------------------- Release summary: Version: 10.18 Last update: 05.01.2026 Type of update: major ---------------------- Find more information about this software on the program web site.
Бот всегда проверяет и включается Валер
вроде и счас Анатолия удалил - за нерешение капчи
А в чем проблема?
Стучитесь.
10.19 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery/ * Access and search for transactions (checkpoints) is now also added for ReFS (version 3.x) file system; * Advanced version of 'Check and assign file name extensions' is now added to the 'Transform file system files' tool with a possibility to configure raw recovery rules use; * Tool to open NTFS restore points (shadow copies) is now added to the 'Transform file system files' tool; - Also added support of shadow copies on ReFS file system; * Microsoft Storage Spaces: - Added support of adaptive reconstruction on dual-redundancy parity volumes (dual XOR, 4-10 columns in rotation); - Fixed issue with opening cache for cached volumes in some scenarios; * ExFAT file system scan: - Fixed issue with skipping some files when they were renamed/moved to a different location (now, 'deleted link' object is recovered at the old location); - Reworked procedure of detection and reconstruction of lost/damaged file system; * FAT/FAT32 file system scan: when object is moved or renamed, the software also attempts to create a 'deleted link' in the old location or with the old name. ---------------------- Release summary: Version: 10.19 Last update: 24.02.2026 Type of update: major ---------------------- Find more information about this software on the program web site.
Hello, please i requested info for upgrade my version but i not have any reply to website form and from your email.
❯ Hello, please i requested info for upgrade my version but i not have any reply to website form and from your email.
Hello! Sorry, we are not able to help you, please contact SysDev labs using contacts on the website.
