28 января 2023 г.
в новых версиях так и должно работать., вроде фиксили это.
у тебя версия какая?
Smolnyj
Вот только что скачанная UFSe Prof ver 9.12
но и все версии более старые, что я за последние года юзал, вели себя так же
30 января 2023 г.
ufsexplorerbot
9.13 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery.php * In sector state map tab UI: - Added standard control toolbar; - Added function of saving map information to a file in UFS Explorer SDMF format (any source format); - Added option of saving map in inverted state; * Added 'Manage all tasks' dialog to set up automatic copying from more than one file at once; * Added 'set caching' function in RAID builder dialog (including 'set to all'); * Added special tool for mass setting of saving processed data from multiple storages; * For Dynamic HTML report now added support of custom HTM-templates (for report 'branding'/'customization'): - Added sample templates to installation for demonstration of dynamic report customization; - Added 'include folders' flag to file search function; * Microsoft Storage Spaces: - Added support of 'type 6' virtual disk descriptor records; - Fixed issue with support of 'type chunk' records (format version 3 and above); * Fixed issue with resumption of 'scan status' (ssdb) of RAID-Z scan; * Added settings for handling map-defined virtual defects; * When loaded associated map of defects for disk image, default 'defect' action is now 'virtually reproduce defects'; * BitLocker properties (Recovery key) now has link to open Microsoft Cloud storage of recovery keys; * XFS file system scan: fixed couple of issues with save/resume scan and deleted file names recovery; * BtrFS scan: - Fixed issue with assembly of multi-component file system; - Better recovery of virtual address space when virtual address space tree is lost; * Fixed detection of LDM on GPT meta partition at long offset. ---------------------- Release summary: Version: 9.13 Last update: 30.01.2023 Type of update: major ---------------------- Find more information about this software on the program web site.
15 февраля 2023 г.
Evg71
❯ Квик скан сделай, будет нормальный размер
Еще пять копеек в эту тему. Если перед отчетом сделать квик скан, то в отчет попадет всякий удаленный мусор. А-ля пустой асин SaveErrorReport.txt Так что предлагаю разработчикам все таки подумать на эту тему.
а именно - убрать не корректный размер папок в отчете, если сканирование не проводилось
7 марта 2023 г.
ufsexplorerbot
9.14 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery.php ---------------------- Release summary: Version: 9.14 Last update: 07.03.2023 ---------------------- Find more information about this software on the program web site.
14 марта 2023 г.
StanislavKorb
Hi guys. Can anyone tell me where I can officially download R.Explorer Pro previous versions? I tried last update and it seemed to me my license is not working on it, so it can be expired.
❯ Hi guys. Can anyone tell me where I can officially download R.Explorer Pro previous versions? I tried last update and it seemed to me my license is not working on it, so it can be expired.
https://www.sysdevlabs.com/product.php?id=ufsxs&user_cat=home&os=win#changelog
StanislavKorb
Its 9.14
Evg71
А что мы перешли на английский? Чат вроде RU там ниже есть и предыдущие версии. Если конечно "UFS Explorer Standard Recovery" тоже самое что и "R.Explorer Pro"
❯ Its 9.14
You are wrong. You could download from this URL https://www.sysdevlabs.com/product.php?id=ufsxs&user_cat=home&os=win#changelog from 7.0 to 9.14. Pay attention, pls.
❯ А что мы перешли на английский? Чат вроде RU там ниже есть и предыдущие версии. Если конечно "UFS Explorer Standard Recovery" тоже самое что и "R.Explorer Pro"
Это несколько странный тип. Лучше не задаваться подобными вопросами, а просто ответить ему по существу, чтобы лишний раз не связываться с ним 💁🏻‍♀️
Да, Вы правы: https://www.sysdevlabs.com/product.php?id=rxp6&user_cat=home&os=win#changelog
На указанном Интернет ресурсе достаточно оперативно возможно подобрать именно подходящую версию и редакцию. Я оказалась немного невнимательна. Спасибо, что поправили 😇
Anamadeya
Some portable devices, like mobile phones, smart watches, MP3 players, etc. store their data in the internal memory rather than removable memory cards. When such a storage is connected to the computer, only a virtual representation of its file system can be opened via Media Transfer Protocol. Meanwhile, the real file system is blocked for access by the manufacturer for security purposes. Low-level access to such a storage may be possible in some cases with Superuser permissions (for example, on Android phones), but rooting a device is not recommended – it may lead to a series of undesired consequences. In the remaining cases, SysDev Laboratories recommends UFS Explorer and Recovery Explorer as effective software solutions for users who need to restore files lost from external drives formatted with FAT/exFAT or other file systems utilized in any operating system environment: Windows, macOS, Linux or Unix/BSD. The software will thoroughly analyze the storage and offer you to copy the found files, while the data source and its structure won't be affected in any way. To regain the files missing from a removable drive with the help of UFS Explorer Standard Recovery, perform the following steps:
❯ Some portable devices, like mobile phones, smart watches, MP3 players, etc. store their data in the internal memory rather than removable memory cards. When such a storage is connected to the computer, only a virtual representation of its file system can be opened via Media Transfer Protocol. Meanwhile, the real file system is blocked for access by the manufacturer for security purposes. Low-level access to such a storage may be possible in some cases with Superuser permissions (for example, on Android phones), but rooting a device is not recommended – it may lead to a series of undesired consequences. In the remaining cases, SysDev Laboratories recommends UFS Explorer and Recovery Explorer as effective software solutions for users who need to restore files lost from external drives formatted with FAT/exFAT or other file systems utilized in any operating system environment: Windows, macOS, Linux or Unix/BSD. The software will thoroughly analyze the storage and offer you to copy the found files, while the data source and its structure won't be affected in any way. To regain the files missing from a removable drive with the help of UFS Explorer Standard Recovery, perform the following steps:
According to this, if I factory reset my mobile using Windows or unlock bootloader using ADB fastboot mode command prompt, is there a possibility to recover my lost data?
Please someone help me
Evg71
In all modern devices you have not chance for data recovery after factory reset.
Anamadeya
I have to recover my deleted files it's very important for me
❯ In all modern devices you have not chance for data recovery after factory reset.
Then what is the solution for my problem
Evg71
Small chance if you get direct access to the NAND chips.
Anamadeya
❯ Small chance if you get direct access to the NAND chips.
Please tell me about this if you knew it
Evg71
Depends on the type of memory on your device
Anamadeya
I am trying my best
But I can't
❯ Depends on the type of memory on your device
OnePlus 5T UFS2.1 2LANE storage
Evg71
Read this please https://forum.hddguru.com/viewtopic.php?f=10&t=43155&mobile=desktop
I think at this time data recovery in you situation is impossible.
Anamadeya
StanislavKorb
❯ You are wrong. You could download from this URL https://www.sysdevlabs.com/product.php?id=ufsxs&user_cat=home&os=win#changelog from 7.0 to 9.14. Pay attention, pls.
И что же во мне странного? Евгений, к слову, меня знает весьма давно 😁. По существу Ваша ссылка ведёт на UFS Explorer. Мой вопрос был про Recovery Explorer. Это разные продукты. По поводу английского. You are wrong - сентенция грубая и оскорбительная, тем более в отношении незнакомого вам человека. Вежливо поправляют фразой you are incorrect.
❯ OnePlus 5T UFS2.1 2LANE storage
It has hardware encryption. No way to recover data by direct chip access, you need security key stored in MCU
❯ И что же во мне странного? Евгений, к слову, меня знает весьма давно 😁. По существу Ваша ссылка ведёт на UFS Explorer. Мой вопрос был про Recovery Explorer. Это разные продукты. По поводу английского. You are wrong - сентенция грубая и оскорбительная, тем более в отношении незнакомого вам человека. Вежливо поправляют фразой you are incorrect.
Коллеги, давайте будем чуток дружнее, и не будем заводиться. Мы все друг друга знаем давно и подобные перепалки не делают нас дружнее. Раз уж начали говорить на иностранных языках, то напишу на сербском. Полако ;) Полако;) Не ругаемся, нам еще вместе и дальше жить.
Anamadeya
It looks like I haven't deleted the missing files because I got this problem when I created a new folder on my mobile and Moves the files in different folders to the new folder and delete the empty folders So this problem was encountered
I don't know if it was deleted or corrupted
Evg71
This is not a factory reset :)
Anamadeya
❯ This is not a factory reset :)
You don't understand what I'm saying
I haven't done a factory reset
Evg71
❯ You don't understand what I'm saying
Maybe. This is russian language chat
