18 октября 2021 г.
ufsexplorerbot
9.1 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery.php * Added Drive/Bridge Security tool: - Decryption of WD drives encrypted with JMS538E, Inic-1607E, OXUF943SE and SW6316 USB bridges; - Support of key block detection both on storage area and in SMART Log pages; - Support of standard AES-256 ECB mode (also AES-128/256 ECB/CBC/XTS modes, depending of chip); - Unlocking of password-locked WD drives (no need to install and run WD Security software); * emulation by pattern recognition in 'read ahead' mode now uses cache (for speed); * Support of macOS ".sparsebundle" disk image format (open as disk-on-disk storage); * Microsoft Data Deduplication: - Software now automatically asks to open and enable MSDDD when file system is opened; - Fixed support of big (over 1GB) files deduplicated with Windows Server 2012/2012-R2; - Fixed issue with opening files from relocated segments; * Decryption of encrypted Apple DMG disk images (version 2/'encrcdsa' format); * Fixed bug with data caching in hexadecimal editor; * Recovery of lost address translation leafs in Btrfs scan (for correct deleted data recovery); * FS with address translation (Btrfs) is now supported for 'status indication' in Explorer; * File and Folder hardlinks deduplication is now made optional; * Fixed few issues with disk imager (corrected number of retries, read block size etc.) ---------------------- Release summary: Version: 9.1 Last update: 18.10.2021 Type of update: major ---------------------- Find more information about this software on the program web site.
17 ноября 2021 г.
9.2 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery.php * 'Transform sector size' tool is extended with options to switch between 512/1K/2K/4K sectors; * Added decryption of encrypted VMware VMDK virtual disks (encrypted VMs for Windows 11 etc.); * Added decryption of compressed Apple DMG disk images encrypted with version 2/'encrcdsa' format; * Write support for VHDX virtual disks (file creation and modification); * In 'Imaging Task' interface: - Added VHDX as target file format option; - Optimized target format selection UI; * Added VHDX as target file format option for Disk Imager; * 'File mask' operations ('search' etc.) now all support multiple values with semicolon as delimiter; * Raw recovery and tool for re-assigning file extensions are extended with more types; * Fujifilm RAW photos format (RAF): - Added extraction of file size, camera 'model name' and 'date taken' in raw recovery; - Fixed issue with file separation to 'preview' and 'tiff' when it is detected by content; * MacOS HFS+ file system: - Enhanced procedure of damaged file system reconstruction and deleted data recovery; - Fixed issue with direct access to highly fragmented file system; * Fixed several issues with Btrfs file system scan. ---------------------- Release summary: Version: 9.2 Last update: 17.11.2021 Type of update: major ---------------------- Find more information about this software on the program web site.
14 декабря 2021 г.
9.3 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery.php * Added experimental support of Synology SSD write-cache: - Recognition and indication of SSD cache partitions; - Applying latest cached data from SSD 'as a delta' to the 'base' volume; * Added decryption of drives from WD MyBook with JMS561 bridge chip; * Fixed several issues with opening files, deduplicated using Microsoft Data Deduplication; * Under Linux, added 'unlock' function for WD drives, locked with WD Security; * File status indication in Explorer is extended with 'zeroed' (bad) state; * Source sector size is now preserved for image files, saved to VHDX and SDLSP formats; * In Linux software version: - Added proper identification of SCSI/SAT drives to support drive serial numbers etc.; - Added support of SMART monitoring for SCSI/SAT-attached drives; * Linux LVM2 logical volumes: - Added indication of logical volume ID in partition properties; - Fixed issue with recognition of 'long' (64K) binary metadata; - Fixed issue assembling multi-segment logical volumes on 'fake' (single-component) mdadm RAID; * For manually defined partitions added recognition of known metadata at defined location; * Reworked FAT/FAT32 quick scan/indexing procedure for better support of damaged folders; * In embedded file viewer: - Added support of HEIC/HEIF photo format (Canon R5/R6, Apple products etc.); - Added decoding of Fujifilm 14bit 'packed' RAF format (models X-A3, X-A7 etc.); - Added decompression of Fujifilm compressed RAF format (models X-T2, X-T3, X-E3, X-H1 etc.); - Defined configurations for many other raw photo formats. ---------------------- Release summary: Version: 9.3 Last update: 14.12.2021 Type of update: major ---------------------- Find more information about this software on the program web site.
23 декабря 2021 г.
mr_white1999
Hi everybody
pc3000velkoo
Есть ли метода в УФС-е пропускать файла при ощшибка при сохранение ?
Pigeon_hd
и по ZFS будет что допиливаться? кейс так и не решился - инфа вся битая оказалась, кроме мелких файлов
❯ Есть ли метода в УФС-е пропускать файла при ощшибка при сохранение ?
Есть, посмотри личку, Богдан тебе ответил.
pc3000velkoo
да , но оно не останавливается на ошибка - а продолжает мучить чтение , Влаера
❯ и по ZFS будет что допиливаться? кейс так и не решился - инфа вся битая оказалась, кроме мелких файлов
По данному вопросу ответить трудно, нет кейсов на которых можно увидеть\повторить косяки.
Pigeon_hd
кейс лежит, на сайте уфс оставлял фидбек со своим контактом, никто не связался
про чатик этот забыл...
24 декабря 2021 г.
По ZFS мы с коллегой советуем также взять на вооружение Data Extractor, который позволяет работать с мета данными ZFS и производить с ними различные манипуляции 💁🏻‍♀️
Pigeon_hd
Из какого по?
Volodymyr Gintov
❯ кейс лежит, на сайте уфс оставлял фидбек со своим контактом, никто не связался
В уфс знают про твой кейс. Нужен сэмпл для тестирования в дебагере, пересылай в Киев . Тут сделают.
17 января 2022 г.
ufsexplorerbot
9.4 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery.php * Added experimental support of QNAP SSD write-cache; * Implemented integrated management of raw recovery rules: - Reworked storage schema for custom raw recovery rules; - Added GUI that shows full list of custom and built-in raw recovery rules; - Implemented simplified interface to create/view/edit user-defined rules; - Built-in editor is set as priority source of custom rules for scan; * Added support of BitLocker decryption using external keys from BEK-files (with no TPM);\* Update to S.M.A.R.T monitoring/log pages reader tool: - Reading of both GP log and S.M.A.R.T log (when possible); - Fixed issue with indication of 'seek error count' when it includes seek statistics; * Added automatic assembly of APFS Fusion drives; * Added indication of encrypted APFS volumes and volume decryption states; * ExFAT scan: fixed issue with recognition of previous cluster size after format; * Implemented ZSTD compression and enabled its support for ZFS and Btrfs file systems; * F2FS file system: added support of 'extra attributes' flag. ---------------------- Release summary: Version: 9.4 Last update: 17.01.2022 Type of update: major ---------------------- Find more information about this software on the program web site.
20 января 2022 г.
Mr. Freeman
Здравствуйте. Подскажите, пожалуйста. Имеестся UFS PRO c хардварным ключом, скачал по ссылке обновление ufsx-pro-rus.zip, но оно уже ругается на истёкшую лицензию. Как получить версию, последнюю для моей лицензии?
Ответил в личку.
30 января 2022 г.
Volodymyr Gintov
https://youtu.be/7GGCOtD-dtg
15 февраля 2022 г.
ufsexplorerbot
9.5 http://www.sysdevlabs.com/download/ufsxpci.exe https://www.ufsexplorer.com/ufs-explorer-professional-recovery.php * Action for activation of partitions with no file system now can be configured; * Disk Imager: - Rework (optimization) of configuration GUI; - Fixed issue with attempting 'multi-sector retries' on defect blocks with 'system' read procedure; * Added setting of file system 'read policy' for storages with defect blocks: - Enabled support of 'read policies' for FAT, FAT32, ExFAT, NTFS, ReFS, Ext, XFS, F2FS file systems; * Added Export/Import function for user-defined raw recovery file types: - Selective export to own XML-based file format for backup or selective restore on different PC; - Partial support of importing user-defined rules in some third-party XML formats; * Optimized 'Refresh' procedure; scan of logical drives is now made optional (by default it is 'on'); * DeepSpar USB Stabilizer/Guardonix: - Added recognition of devices with no media or when it is not powered on; - Added power control and support of driver configuration; * ExFAT scan: added processing of CheckDisk .CHK files (when possible), fixed few more issues; * Raw recovery scan: found and fixed 'scan stuck' issue; * Update to S.M.A.R.T monitoring tool: added 'SSD life' indication and support of SCSI Log Sense; * Added indication of storage device type and rotation speed for HDD. ---------------------- Release summary: Version: 9.5 Last update: 15.02.2022 Type of update: major ---------------------- Find more information about this software on the program web site.
16 февраля 2022 г.
pc3000velkoo
В последняя версия у меня не работает копирование и save processed data . Проверьте у себя пожалуйста
А ключ у тебя актуальный?
pc3000velkoo
Да , и версия последняя
Evg71
Введи его еще раз
pc3000velkoo
попробую деинстал и инстал если только у меня такое
зачем Женя ? пишет лицензировано - файли сохраняет
Evg71
ну тогда ой. У меня слетала активация как-то
pc3000velkoo
не хочется пока преинсталировать , другое екзе копирует вагон данних счас
17 февраля 2022 г.
Дима, перекачай с сайта софтину, поставь еще раз.
pc3000velkoo
Оки Валер :) Спасибо !
23 февраля 2022 г.
Evg71
битая SGI XFS partition enable Map of bad sectors > по сигнатуре сканирую только файловую. Сканирует. По окончании когда должно отобразить дерево файловой, программа задумывается и сворачивается без всяких сообщений. Без "enable Map of bad sectors" нормально сканирует и отображает дерево файловой
Пробовал на 9.5, 9.4, 9.0
1 марта 2022 г.
Каким образом средствами UFS v.9.5.0.6266 возможно и возможно ли в принципе расшифровать NTFS-том, зашифрованный BitLocker в связке с TPM v.2.0? NTFS-том находится в GPT-разделе побитовой копии носителя информации. Актуальные аутентификационные данные в виде пароля и ключа восстановления имеются. Фрагмент ключа восстановления BitLocker в GUI форме UFS отображается корректно и полностью совпадает с фрагментом из его полной версии. Использование альтернативных способов, отличный от функциональных возможностей UFS, прошу не предлагать, так как вопрос касается исключительно Галисия или отсутствия данных функциональной возможности в UFS и только.
Evg71
Recovery key вводится вместо пароля
https://www.youtube.com/watch?v=Jg9JQ1pdhnM
"побитовая копия" - это звучит круто :)
❯ Recovery key вводится вместо пароля
Всё верно 💁🏻‍♀️
❯ https://www.youtube.com/watch?v=Jg9JQ1pdhnM
В Recovery Explorer Professional v.9.2 всё успешно открылось, но в UFS v.9.5 нет 🙍🏻‍♀️
❯ "побитовая копия" - это звучит круто :)
Вполне штатное и формализованное словосочетание. В англоязычных материалах форензикаторов – bit-to-bit copy.
Evg71
не надо повторять глупости
❯ не надо повторять глупости
В смысле глупости? Это принятое, формализованное, технически корректное и допустимое словосочетание в DFIR и eDiscovery комьюнити 💁🏻‍♀️
