16 декабря 2021 г.
Parth516
hello friends
17 декабря 2021 г.
❯ hello friends
Hi comrade
22 декабря 2021 г.
Ник
Здравствуйте. Кто может поделиться распиновкой внутренних контактов microSD 6x4?
На сайте АСЕ имеется
23 декабря 2021 г.
1866851197
Hello experts I know my issue is probably too easy for you,please forgive me. Im a new pc 3000 UDMA user and a data recovery newbie here.Im really struggling with the board setup.Kindly point me to the right direction guys. The issue is with the physical connection,connecting the UDMA to the power supply. I have installed the drivers from acelab website but I do not see the UDMA-E controller in the device manager. If there is anyone with a picture of the board installation connection or the board setup,connection of board to power supply,I could follow from there. Thanks a million guys.
b1 system
May be your motherboard very old? OR MB bios settings not correct. PC3000 PCB first must detect in device manager - Unknown controller , Next step - need install driver for PC3000, and last step - install software.
You are trying to install software whithout preinstall driver for this card
Sorry for my bad English:)))
1866851197
Thanks you very much Aleksey and your English is good enough🙏🏻
Your shoot contact ACELAB or their representativ
❯ Your shoot contact ACELAB or their representativ
And may be move PC3000 card to another slot
1866851197
Thanks Aleksey,I contacted them and they say I should connect sata power cable to UDMA.I was hoping that you can show me how because I tried connecting and did not get the controller on IDE,maybe i connected wrong cables.if you have a connected UDMA picture,can you show me how you connected to motherboard power supply.
❯ And may be move PC3000 card to another slot
yes I moved to other slot,no detection.
May I ask how you connected the sata cable to power supply?
teamblackhat777
Hey any one using ufs explorer
Oleg Gritsev
yes
all people use UFS
teamblackhat777
Which is better ufs or r -studio
Oleg Gritsev
UFS complicated but in some cases possible retrieve more data than use r-studio.
also UFS works with BTRFS
❯ Thanks Aleksey,I contacted them and they say I should connect sata power cable to UDMA.I was hoping that you can show me how because I tried connecting and did not get the controller on IDE,maybe i connected wrong cables.if you have a connected UDMA picture,can you show me how you connected to motherboard power supply.
Check bios settings for PCI Ex slots. May be not compatible ? Or connect in to other MB (for example we use intel i5, i7 cpu MB LGA1150, LGA1155, LGA1151,LGA2011,2011-3 tested by me)
1866851197
❯ Check bios settings for PCI Ex slots. May be not compatible ? Or connect in to other MB (for example we use intel i5, i7 cpu MB LGA1150, LGA1155, LGA1151,LGA2011,2011-3 tested by me)
Thank you very much for your time Aleksey,I will do that and I will continue trying🙏🏻🙏🏻🙏🏻
25 декабря 2021 г.
Lawrence
head 1 when acces show this error on Terminal
31 декабря 2021 г.
AmarrKhanid
Дорогие друзья. Простите за оффтоп, но хочется поздравит вас и ваших близких с наступающим, 2022 годом и пожелать добра и благополучия ! Берегите себя и не болейте :)
Aurel Panasel
Неподдерживаемый тип вложения 3.
DiriElectronic
1 января 2022 г.
С НОВЫМ ГОДОМ
С НОВЫМ ГОДОМ
dumbmode
❯ Дорогие друзья. Простите за оффтоп, но хочется поздравит вас и ваших близких с наступающим, 2022 годом и пожелать добра и благополучия ! Берегите себя и не болейте :)
С Новым Годом, коллеги! Желаю всем денег, здоровья и удачи в делах и ремонтах.
11 января 2022 г.
sergefrem
Коллеги, здравствуйте. Smartbuy splash 3 на 88nv1120-btz2. После чтения паспорта bsy, потом отдупливается с пустым паспортом и отсутствием трансляции. По всей поляне паттерн 1b 00 00 00, местами попадается goodbye. Acelab только еще начинает их ковырять, но данные к тому времени протухнут. Кто-то победил такой случай? Отправлю клиента.
13 января 2022 г.
Дмитрий
Game over не пишет?
Паттерн - код ошибки.
15 января 2022 г.
sergefrem
Game over не пишет. Вместо него good bye, но без явно выраженной периодичности. Не нагуглил расшифровку кодов ошибок, она уже где- то выложена?
28 января 2022 г.
xzhi99
你好
29 января 2022 г.
Oleg Gritsev
❯ 你好
yes it available from manufacture support.
какого перепугу тут трындеть и строчить на чайнизном диалекте если никто не вразумит? это помойка?
