Всем спасибо и доброй пятницы :)
❯ вот тут было нестизначное число .
туда вообще смотреть ненужно)))
❯ туда вообще смотреть ненужно)))
как я по этим HGST посмню - отсканили, загнали в плист через глист
или я что тоне так делаю ? они не так часто попадаютсч
очистите ему G-List и потом очистите смарт - смарт станет красивым, а вот дальше уже попробуйте формат и заново тесты
Багодарствую !
有没有pc
Pls suggest mobile data recovery best software Android
Celebrite, XRY, magnet forensic, they are the best.
❯ Pls suggest mobile data recovery best software Android
Cellebrite Physical Analyzer, MSAB XRY Physical and Oxygen Forensics Expert, but not a Magnet Forensics AXIOM.
❯ Cellebrite Physical Analyzer, MSAB XRY Physical and Oxygen Forensics Expert, but not a Magnet Forensics AXIOM.
Yes magnet forensic itself have only logical extraction. And some roof features. But it have good grayshift chack option! Oxygen not powerful. It is Russian soft. Russian Ace lab mobile also not bad but have limited phone support. We have all this licences shared soft. But with comparison - the best option it soft from manufacture for each cellphone with data sheet and service manuals from support.
Pls help Bitlocker hardisk remove password please help me
❯ Pls help Bitlocker hardisk remove password please help me
Unreal without Recovery Key, or RAM dump, or MA full access, or password (without TPM)...
❯ Unreal without Recovery Key, or RAM dump, or MA full access, or password (without TPM)...
remove password
❯ remove password
HDD's password or BitLocker's password?
It's a BitLocker's Password. Forget about this case.
In this cases you need Recovery Key, or RAM dump, or MA full access....
❯ In this cases you need Recovery Key, or RAM dump, or MA full access....
Possible take it from TPM module or you still have original computer, or use some methods to find key, or use bitlocker key mining soft. But last one available only for law enforcement.
❯ Possible take it from TPM module or you still have original computer, or use some methods to find key, or use bitlocker key mining soft. But last one available only for law enforcement.
And? I know everything about BitLocker in DF cases, but I'll never give a full answer in public chats. You should respond to author's question (@ddthhhuh), not me.
❯ And? I know everything about BitLocker in DF cases, but I'll never give a full answer in public chats. You should respond to author's question (@ddthhhuh), not me.
Responded.
Доброго дня. TOSHIBA HDWG180 как я понял комплексом не поддерживается ?
❯ Доброго дня. TOSHIBA HDWG180 как я понял комплексом не поддерживается ?
если на ней стоит защита то нет. На части дисков которые поддерживаются, сейчас тоже попадается защита и они тоже уже как бы и не поддерживаются.
HDD ID Reading.......................... : Techno Off error : Device Error Detected 51/04 (ABR) Techno On............................... : Device Error Detected 51/04 (ABR)
g-sense - 1 и система ругается просили смарт сбросить=(
Ну дизассемблер вам в руки и вперед к новым знаниям
Не стоит оно того 😁
From $6000 till 14000 USD. For North America. Other countries have different prices.
Haw much udma ssd support
3000
Pc 3000 udma
Support us free.
Where is Cheapest price of pc3000 in world ???
❯ Where is Cheapest price of pc3000 in world ???
at Russia
Hi i need ms SQL repair software with crack pls help me friends
Привет, мне нужно программное обеспечение для восстановления MS SQL с трещиной, пожалуйста, помогите мне, друзья
Выбранное семейство..................... : Kingston A400 Контроллер.............................. : CP33238B (PS3111) при преформате висит на Очистка SSD
Доброго дня. проблема аппаратная ?
Очистка SSD **************************************** Запуск очистки SSD (0x05)............... : HDD Redynes timeout (300000) Operation aborted
Why u need firmware for him?
